-   -   K&N filter top cap for marine use (https://www.offshoreonly.com/forums/general-q/276628-k-n-filter-top-cap-marine-use.html)
87MagnumII 05-16-2012 09:36 PM
Was wondering since a lot of us are confined to flame arrestor size because of clearance issues if we could safely and legally use one of these to gain more air flow:
https://www.knfilters.com/universal/X-stream.htm
If not could somebody please explain what makes them different from the marine flame arrestor material. To me it appears to be the same stuff they use for cars.
mr3dman 05-17-2012 10:32 AM
I could be wrong but I am pretty sure that marine arrestors can withstand a backfire and not blow the filter media and contain all the associated flame within the filter. Automotive styles like the one you posted may blow out the filter media allowing a flame to enter the engine compartment. becides, if you have a fire and the arrestor isn't uscg approved no claim will get approved
HTRDLNCN 05-17-2012 11:40 AM
marine arrestors are meant to contain fire/flame they do not filter the air ,
no reason to filter air when your on the water...
No dirt in the air.
I would not run without a flame arrestor,, in a closed compartment a backfire could end your day or your life..
Pismo10 05-17-2012 12:43 PM
You would need to replace the medium with metal medium like the screening used in a regular flame arrestor.
87MagnumII 05-17-2012 02:11 PM
I understand that it has to be USCG approved. I'm currently running a k and n marine flame arrestor. My question is if we could safely and legally use the top cap from k and n on the marine flame arrestor. The k and n marine flame arrestor appears to use the same medium as the automotives do. But I may be wrong on this.
ThisIsLivin 05-17-2012 02:12 PM
I actually just received a 14"x4" K&N Marine flame arrestor, and I cannot tell the difference between it and all the K&N's I've installed in my land vehicles. I honestly believe the only difference is the special marine SAE stamp on the element and the USCG approved stamp on the base. I'm fortunate enough to have a little room under my deck and the deck has a built in ram air intake system with dual NACA ducts on the sides. I will have to cut a little of the under side of the deck to clear the taller filter, but this now places the flame arrestor squarely inside the fresh air system. I found a custom velocity stack that will work with a 14" filter with a top that is shaped like the K&N air horn device to smooth air into the carb. Be careful when selecting an arrestor of any type, some of them don't flow much air. I was originally looking at the K&N 9" which comes on a velocity stack. I called their tech support and the 9" won't flow enough air for my 524 and will create enough vacuum to close my power valve.
