-   -   Freeze damage? (https://www.offshoreonly.com/forums/general-q/276799-freeze-damage.html)
Fast Algae 05-19-2012 11:28 PM
Freeze damage?
7.4 mpi.
Has anyone seen freeze damage bad enough to pop the freeze plugs but nothing else? Just wondering what the odds are. Engine ran fine for about 2 minutes or less before I discovered the water pouring out the side of the block. Manifolds did not get hot or anything.
Is it possible that the only thing I would have to do is replace the freeze (casting) plugs and be on my way?
Fingers crossed so hard it hurts.........
cubicinches 05-19-2012 11:33 PM
Yep. I've seen it a few times. Just had to replace a freeze plug or two.
Keep an eye out for any signs of water in the oil. Chances are it would show up immediately, but ya never know.
Fast Algae 05-20-2012 12:19 AM
If it seems OK, drive it hard for an hour, yada yada, would you pull off the intake manifold to check out the lifter valley anyway to be sure?
If there is damage, I need to find it right away - because if it shows up later, I may have to pay for it....
cubicinches 05-20-2012 12:25 AM
If you had damage in the lifter valley, you'd have water in the oil.
articfriends 05-20-2012 12:54 AM
bbc or small block? The small blocks I have seen that froze had cracks in the lifter valley and some didn't even have the soft plugs pushed out. You might know this already but soft plugs were never meant to protect from freezing whatsoever, they simply seal the holes where the casting core sand risers/core mold form the cooling jacket and so that core sand can get out after the casting process. If you didn't have actual cracks you are real lucky, I hope you arre, Smitty
Fast Algae 05-20-2012 01:27 AM
It's a 7.4 mpi.
So freeze damage does not show up in the valley as much with big blocks?
dereknkathy 05-20-2012 06:22 AM
i have seen 1 bbc with crack running down lifter valley in the scrap pile. i have the crank and 4-bolt main caps in garage from it. i tried marine tex-ing up same crack in a v-6 a guy promised me he had winterized...it worked for a week.
mrv8outboard 05-20-2012 07:16 AM
I have a GEN V 7.4 here that did not push out the core plugs but has a long crack front to back between them.
rumrunner29 05-20-2012 07:52 AM
Years ago with my first boat, my winterizing skills were not so sufficient and I didn't get all the water out. It popped one of the freeze plugs out of the starboard 454....Engines were coming out for a rebuild anyway, so everything was checked when disassembled at machine shop. No damage was found except for the plug.....I was lucky.
dereknkathy 05-20-2012 08:12 AM
what do you mean? did somebody else winterize this boat for you? if so, i would be all over them already!!! i would be screaming for a new engine, because you can't know if it cracked where you can't find it and will leak later. the only way to be SURE is to strip motor to bare block and have it magnafluxed. if you don't see a crack in valley, and water and oil both stay where they belong, you are probably ok. but if it is somebody else's responsibility, at least get it documented now. and make THEM do freeze plugs and r&r the intake. just make sure you eyeball the valley before it is reinstalled...
Fast Algae 05-20-2012 09:20 AM
Yeah, local shop did the winterize. It is a great place, with a great rep, nice guy who said he would make it right. I just want to make sure if we just put some plugs back in, that I truly dodged a bullet.
You can be sure I will run the hell out of it to find out.....
kubelwagonman 05-26-2012 07:23 PM
usually bbc crack from a water passge to lifter valley under the head,cant see but,,,,,,run it to operating temp on hose,itll show sings of water quick..also see if oil level is high on dipstick....maybe pull pan bolt an see if yu get water out 1st....
Twin O/B Sonic 05-26-2012 09:14 PM
You'll either see water in the bilge or in the oil. Will happen quick too. On the hose in the drive way should show you what you have.
I've replaced several motors for customers up north yrs back due to this.
Also had twin inboards in my personal cruiser (also yrs back) do it to me. They were small block Chryslers though and popped the ones in the back of the block, in front of the bell housings. Was very lucky and that was only damage too.
Also lost a car motor when up north too. Same thing though. I knew instantly and was no disguising it.
Fast Algae 05-27-2012 01:17 AM
Gone three trips and over 5 hours now. I dodged a bullet BIG TIME.
No oil problems still looks new.
Jeff P31 05-27-2012 07:28 PM
Why not just pressure test it instead of taking the intake off and looking for a crack you are not going to see any way . Just a thought :whistle:
mach1magnum 05-28-2012 06:16 AM
where do you live i know here in mass we had a pretty mild winter maybe you got lucky
chadman99 05-28-2012 07:41 AM
happpen to me 2 years ago in my 502 only problem it was one behind the block inside the bellhousing so the motor had to be pulled ,replaced it and all was good no other damage alot of work for a 10 dollar part but i counted my blessings that it wasnt a cracked block and i was able to repaint the bilge while the motor was out
