-   -   496 iac (https://www.offshoreonly.com/forums/general-q/276888-496-iac.html)
jab052783 05-21-2012 12:22 PM
496 iac
My port engine makes a lot of vacume noise at an idle it comes from the hose from the iac on the back of the intake that connects to the throttle body is this normal I only ask because the starboard engine does not make the same sound both engines idle and run perfectlty though
Plum_Crazy 05-21-2012 12:54 PM
Is the little muffler still there? It's number 5 in this pic.
jab052783 05-21-2012 01:24 PM
496 iac
I am not sure I will check it when I get home from work though
jab052783 07-31-2012 03:23 PM
496 iac
The little muffler is still in place and when I take the hose from the IAC to the throttle body loose near the throttle body there is a lot of vacume pressure on the hose is this normal?
