-   -   350 Mag Water Pressure and Temperature (https://www.offshoreonly.com/forums/general-q/277029-350-mag-water-pressure-temperature.html)
sp3132 05-22-2012 10:31 PM
What should the water temperature be on a 350 mag? Also, what about water pressure? I have about 15 pounds of water pressure at 3500 rpm and the temp runs about 180 degrees.
How far would I have to put drive into water when lowering on a lift to check water flow as the guage shows zero-2 pounds at idle?
osur866 05-22-2012 11:50 PM
That sounds about right to me, my 6.2 runs the same
