B&M 250 lower pulley installation >
Old 05-21-2012, 11:09 PM
Default B&M 250 lower pulley installation
I need some experienced people with blower pulley installation.
I am in installation of the lower blower pulley and v grove blet pulley and i am in questioning on the center 1/2'' bolt that bolt into crankshaft to hol the balancer. That i need to have a longer 1/2'' x 4 1/2'' long center bolt to hold all the pulley, spacer and balancer together?
Or just bolt the pulley with the 3 x 3/8'' bolt into the balancer and balancer bolt separate into crank ?
supermx96 is offline
Old 05-22-2012, 07:55 AM
rgrgoog's Avatar
I am no expert but this attachment may help you.
rgrgoog is offline
Old 05-22-2012, 10:36 AM
737jetmech's Avatar
Install the longer 1/2 " ( grade 8 ) bolt . With the correct spacer it is not possible to do it any other way .
737jetmech is offline
Old 05-22-2012, 07:18 PM
Old 05-22-2012, 07:24 PM
Mine used a standard balancer bolt, with the large washer. Then, the accesory pulley goes on, spacer, drive pulley, then install the 3 long 3/8" bolts that hold all that to the balancer. In other words, the balancer goes on first and is torqued down. Then everything else gets bolted on
MILD THUNDER is offline
Old 05-22-2012, 09:24 PM
Ok, the 3 long 3/8 (grade 8) bolt is enought strong to hold all the pulley on the balancer?
Old 05-22-2012, 09:27 PM
Worked for me.
Old 05-24-2012, 07:43 PM
Worked for me.
Above post are correct. I have a 250 blower and ended up coming across a 420 lower pulley set up that bolts up a little different. I liked the 420 lower pulley mounting style more than the 250 style so that's why I went the direction I did. The 420 lower pulley is a tad bit smaller than the 250 so I will loose a little boost from it but it shouldn't be a whole lot.
mustangmark is offline
