-   -   Looking for lower half (https://www.offshoreonly.com/forums/general-q/27725-looking-lower-half.html)
Mack312 06-30-2002 08:42 PM
Gents and Ladies,
I am looking for the best place to purchase the lower half
of a Bravo 1. It has 1.65 R gears and a low water pickup.
I would like to get it ordered and shipped Monday. Would like
to see it at the house on Wednesday. Do I have a chance at this?
I don't think I can have another skeg (spelling) welded on. Am going to keep the damaged unit as a backup.
HELP!!!!!:D
and thanks.
Mbam 06-30-2002 09:16 PM
Mack312, a complete new drive is not much more than a lower only. We have the latest version in stock for $3800, could ship via Delta (airport pickup) for less than $100, you would have it by Tuesday
Mack312 06-30-2002 09:43 PM
MBAM,
Need to keep them the same these are on a 2000 312 Formula.
Would the "latest version" be the same as the port? Also, Can I get a number to call you on Monday?
Joe
PS Looked on you web. A lot of help :) !
Mbam 06-30-2002 10:31 PM
Joe, number is 954 321 0606. The new units all have the dual water pickup. We have a couple of the older style available, but the new one is so much stronger I would hate to see you go that route. Give me a call if you want.
Mack312 06-30-2002 11:04 PM
Thanks. I'll call you in the AM
Joe
Fountain38 06-30-2002 11:12 PM
Broken Eliminator
hey Marc, I am in the same boat (Ha Ha) not to funny really!
I cracked my lower 1:36 starboard housing and broke my prop shaft today. Need some help! Either I need to get it welded? or new housing? or welded and replace prop shaft and prop, or maybe a new lower, but mine has a "leading Edge" nose cone installed by eliminator. Any help would be appreciated
All this by Wed so I can play on the 4th
Robert
Mbam 06-30-2002 11:21 PM
Robert,
I don't think welding is a great idea, depends on where the crack is. Also, you should strip and Zyglo the rest of the unit looking for more cracks. You could change to the XR style prop shaft, but that puts more strain on the upper.
Sorry for the problems you guys are having, but boy, I can tell tommorrow is going to be busy!
Fountain38 06-30-2002 11:55 PM
lower half
Thanks for the help Marc,
I may just call you tomorrow. I have friends that lives close by and works as a engineer for Mercury. He's going to look at it tomorrow. How many dollars to just upgrade to XR drives,and will they just bolt on with out any problems.
Robert
birdog 07-01-2002 07:22 AM
MAN!!!!!! You cant beat that service!!!!!
Joe.....Order it now!!!!!
With the luck you having...good thing to have
Also i will know where a spare is!!:D
Mbam 07-01-2002 07:45 AM
Robert, XR's are $6500 each. You also need to change the gimbal bearing, the sleeve that holds the belows in and add 2 little spacers to each trim cylinders. It is about $60 in parts, a couple of ours work.
