-   -   Risers getting to hot. (https://www.offshoreonly.com/forums/general-q/277578-risers-getting-hot.html)
Austin 05-30-2012 04:50 PM
Hey guys... it’s been awhile. I’m having an issue that I just can’t seem to figure out so I’m throwing it out to the experts. 6.2’s with Stainless Marine manifolds other than that totally stock. Port motor steams, and the risers are hot as hell, but the block seems cool. After running I can take the block plugs out of the bottom of the motor and the water is only warm, but I still can’t put my hand on the riser. I have taken the thermostat out. No water in the oil and everything else seems fine. Any ideas on where I should be looking to solve this????
Redhook98 05-30-2012 05:41 PM
Risers. Usually steam and a hot riser is an indication of a bad riser gasket or partially blocked riser (i.e. rust). You stated you have Stainless manifolds, but what are the risers made of? I would start there.
Water is not circulating through your risers at a fast enough pace to cool them properly. They get hot and steam is produced....
Austin 05-30-2012 05:53 PM
Risers are stainless and not blocked. I have backflushed the mainifolds but not yet removed them. Other motor is running cool and has the same amount of flow.
Austin 05-30-2012 06:42 PM
I just took the manifold off to try and shake any obstructions out... got a closed handfull of sand- not much. But I did have white crust from the top of the riser all the way down and into the middle two exhuast ports on the head. Not much but it was there. Pulled all the plugs and they are all a light white/brown and all four seem about the same. I'm still stumped. I will try and switch the raw water pumps tomorrow and see what happens.
US1 Fountain 05-30-2012 06:49 PM
How are the risers getting hot, yet the motor is only warm?
Are you dumping water to lower pressure?
Expensive Date 05-30-2012 07:10 PM
When they were installed did you or whoever did it change the plumbing? If it still is stock the 6.2s use a check valve on the bottom of the manifold, its possible that it is clogged or stuck. Did it always do this or did it just start? If I remember correctly your boat was repowered by Pantera a few years ago.
Redhook98 05-30-2012 08:04 PM
May be losing some pressure. Sand in your manifolds got there somehow. That somehow would take it through the water pump. Sand in the water pump could be a killer. Maybe your losing pressure at higher RPM levels due to premature wearing in the water pump? Forgot about the check valve also...
There is really only a few things it could be. White crust is dried salt/corrosion. It got there somehow...
Austin 05-31-2012 06:26 AM
Bravo Fever....
Does anyone know the part number for the plastic hose retainer??
Also do you think it's plausible that with reduced water flow it made it easier for saltwater to back up into the two middle cylinders??? Or should I be hunting another problem??
Griff 05-31-2012 10:50 AM
Originally Posted by Austin (Post 3699166)
Bravo Fever....
That makes sense. It has enough flow to cool the engines, but is not bypassing as much water to the exhaust.
Not sure of the part number, but I'm sure you can find it on www.mercruiserparts.com
I would order 2 of them, since the other one may not be far behind.
dereknkathy 05-31-2012 05:44 PM
try switching the two thermostat housings. if prob goes to other engine you have it.
Austin 05-31-2012 06:11 PM
Problem found... Bravo Fever- when the water inlet in the from the drive through the transom assembly compresses due to salt build-up( parts on the way over). Also had a bit of water reversion due to bad seals at the riser/manifold connection. Going to get spacers to raise the riser as far as possible and reseal the joints.
Expensive Date 05-31-2012 06:14 PM
What is a plastic hose retainer? Did you pull the water pickup off the transom to make sure its not clogged? Lift keep boats have a problem with that.
3 minutes too late, glad you found it.
Wes Burmark 05-31-2012 07:54 PM
Austin, I talked with my technician today. He just finished servicing the water pumps on my 6.2 MPIs. They are the late style bronze pumps and he said there is an update kit for them as the impeller wears ridges in the bronze over time. The update kit included a ceramic surface for the impeller to run on. He claimed it gives a nice increase in idle PSI. When I pick up the boat I will post the part numbers. Sounds like you have everything under control now but I thought if you didn't have the update kit in your pumps it might be of interest.
Austin 06-01-2012 07:53 AM
Wes, Yes those are the pumps I have and they do have groves in the bronze. I would be interested in the kit. Although my idle pressure is low the biggest issue was definately the retriction at the transom plate... couldn't even get my pinky finger in the hose.
Wes Burmark 06-01-2012 10:52 AM
Austin, I will get the info to you sometime next week when I pick up my boat.
boatnuts 06-08-2012 01:39 PM
I would like to know about the update kit as well
Wes Burmark 06-08-2012 07:23 PM
I looked at both brass water pumps. There were grooves in both pumps. #47-862232A2 was the impeller kit number he installed. In Mike's notes he said, "Wear plates on W/p's are grooved too bad to reuse. New plate is plastic with stainless steel ware plate." The impeller kit was $34.17. A new impeller housing was #862776A01 - $99.98. The new seawater pump was #46-862914710 for $401.25. I know there are many opinions on impeller replacement but Mike said there would be no need to replace the impellers until they had 100 hours on them. As the Fountain has water pressure gauges I'll keep an eye on them and see how slowly or how quickly the pressure goes down as I put hours on the boat. Hopefully these part numbers will be of value to some of you. Again, my ride is a 29' Fever with 6.2MPIs.
