The only difference I have ever seen from the 260 horse 350 to the 270 horse 350 mag is the intake and a slight jet change.
2 bolt, cast cranks in both. The mag intake is a great intake. If you look closely, it really looks just like an edelbrock rpm performer. Downside is that it is heavy at 45 pounds vs. 15 for the aluminum performer. I have a very similar vortec 350 as 87magnumII. I have a scat cast crank that they rate up to 500hp, rpm air gap, LT4 hot cam, SM exhaust etc. Running a 600 edelbrock. Have a 750 as well and they are very close, probably stick with the 600. Running 63 very easily in a formula 206. Gonna try a different prop this weekend because I believe 65 is very possible. There are a couple of simple mods you need to do to the vortec heads. Screw in studs, oversize pushrod hole, and run beehive springs to accomodate the higher lift of the lt4 cam. As for the old style heads, I think they are maxed out at 270 horse. |
Originally Posted by michaelb63
(Post 3703715)
mine is a 350 mag didnt the mags come out with forged cranks and rods,the intake is a 14096242 dual plane high rise ,but it looks like it weighs a ton. :party-smiley-004:
Originally Posted by Mr Maine
(Post 3703850)
(Post 3705142)
looks like im buying a new set of heads,may as well get an aluminum intake while im at it.anyone want to buy a boat anchor of a manifold ? :daz:
| All times are GMT -5. The time now is 02:55 AM. |
