Trailer Bunks?
I have an aluminum trailer with the 2 large bunks at the back and then there are 2 rollers at the front, holding a 38 ft fountain. I would like to add some bunks to the front as well as the back to make it easer to load the boat( it's very difficult lining it up with the front rollers, I always have to have someone spotting and guiding me on them.). What size lumber should I use and does anyone have any pictures of there trailers with what I am looking for for bunks or if anyone has any other suggestion to make loading easer. Sorry for the long post. Thanks Eric
The bunks on my trailer are wolmanized 2x6's wrapped in outdoor carpet.
I have guide poles on my CAT trailer and i don't give a crap what anyone thinks about it! Since the wie and I float the boat off and on and need to go pretty deep to do so the guides work out great for us and we can unload in a minute flat and load in about 2 minutes once the lane on the ramp is clear. Takes longer to load since I have to get out of the truck to hook up the safety chain and winch cable so the boat doesn't slide off the wet bunks. Maybe some smaller side guide bunks to get you centered?
Originally Posted by fireboatpilot
(Post 3708570)
4 Attachment(s)
Heres a few pics. I know it looks silly but it really helps. Guides the boat right into the center, hook it up and drive off.
http://beautifulmauicondo.com/boatpictures/IMG_0799.jpgEsal,my boat is in the water so I went up to the garage and took out the tape measure. I have a 29' Fever so sorry you will have to do some enlarging estimates to figure out your bunk lengths but for what it is worth... (I took pix if you want to send me your email address) here are the measurements off my Venture aluminum trailer. Rear bunks are 3" wide x 8" turned up on end. They are 11'2" long and are 35" apart when measured at the tops. Front bunks begin about two feet in front of the rears. They are 2"x6" lying flat as slight angles. They are 5' long and are 3" apart at the insides. All wood is covered with the usual black carpet. The four bunks support my boat. Good luck with your project.
Where do you get the mounting hardware?
It's kinda funny, but I started measuring to do the same thing 3 weeks ago so I was really glad to see this thread. My trailer is set-up the same as Wes's except for the front bunks which is what I'm wanting to add. My trailer is a Loadmaster and I have to add a short crossmember to support the front of the forward bunk. Loadmaster has them and brackets on there webpage so you might check with them for parts. Wes's pic shows exactly what I'm going for on my 27' fever. Good luck and thanks for the thread!
| All times are GMT -5. The time now is 08:28 PM. |
