-   -   Water circulating pump 454 v belt verus serpentine (https://www.offshoreonly.com/forums/general-q/278616-water-circulating-pump-454-v-belt-verus-serpentine.html)
Esal 06-13-2012 10:09 PM
Merc calls for the same part number for a serpentine belt setup as they do for a v belt setup. A serpentine setup will spine the pump the opposite way. The questionis, is there a difference in the two pumps even though merc calls for the same part number? The reason I ask I had a v belt one sitting around and was going to put it on a serpentine setup. Will it work? Thanks for any help
Mbam 06-14-2012 04:26 AM
If the part number is the same there is only 1 pump. Years ago there were 2 versions.
