Originally Posted by Young Performance
(Post 3710867)
You said the lines and such were replaced from the pickup. Was the pickup itself replaced? Every Baja I have ever seen has a small plastic pickup in the tank. It has a square 90* fitting on top. An adapter fitting screws into the square 90* fitting. When the adapter fitting goes in, it ends up blocking half of the already small hole in the pickup. Has the filter head been replaced with a larger one? Is the fuel being returned to the tank? If not, it can/will cause aeration if it is being returned to the inlet side of the pump, especially with a larger pump.
Here is a pic of a fuel pickup that came out of a Baja. Next to it is one that we make to replace the small plastic ones. Does yours look like this? Were ya'll watching the fuel pressure gauge while running hard? I suspect you have a fuel delivery problem. Eddie |
Originally Posted by MER Performance
(Post 3711094)
Eddie, Is that a -12 - 1/2 npt or -10 - 3/8 npt?
Eddie |
Originally Posted by andychb
(Post 3710973)
A little off topic but what was the pitch of the prop and how fast was it turning when you hit 98 mph.....was that on gps ?
Eric, yes, set up right your boat should last you at least 100 hr between rebuilds, probably 3 or 4 times that at 4 psi of boost. Something is definately wrong, afr gauge on the motor in the boat along with a accurate fuel press gage will tell you everything. What size injectors are you using, Smitty |
| All times are GMT -5. The time now is 11:54 AM. |
