-   -   motor never gets over 115 degrees. ok? (https://www.offshoreonly.com/forums/general-q/278824-motor-never-gets-over-115-degrees-ok.html)
mookster 06-17-2012 09:58 PM
all new gauges and senders plumbed in the intake. running b&m blowers with no thermastat and a cross over.
do i need to get my temps higher some how or running like this be fine?
Jeff P31 06-17-2012 10:57 PM
I watch the oil temp's . same sort of setup and it has worked fine for years .
supermx96 06-17-2012 11:21 PM
I have try to run with no thermostat (with hole restrictor) on cross over setup and the engine can not warming up in my casse i run in 65-70 f water temp. i have notice also with no thermostat my oil presure stay hight like when i start the engine when it is cool.My engine have the stock oil thermostat and the oil seem to stay too cold without water thermostat. I prefer to run at 150f and 160f after hard run. I have drill 4 x 3/16 hole in my thermostat and i will probably drill one more. Start with 3 x 3/16 hole and see what the gauge say.
You will need also a bypass hose between the cross over and the th housing to get enough water in exhaust when the th is close. The bypass is the reason that you need to drill hole in (stock merc) thermostat because the thermostat is afected by the cold water coming in front of them.
Hope that's help.
mookster 06-18-2012 05:19 PM
i dont have the stock mercury setup.
GPM 06-18-2012 05:26 PM
A lot of people run blower motors cold to help control detination.
