-   -   Trim pump Solenoids (https://www.offshoreonly.com/forums/general-q/27943-trim-pump-solenoids.html)
CelticPride 07-03-2002 09:19 AM
Trim pump Solenoids
Here's the problem. The trim pump works just fine when lowering the drive....if I lower it and then immediately raise it it will rise. If I lower the drive and let it rest then attempt to raise it, I can here the solenoid click put the pump does not run. If I hit the down switch then up it will trim up.
WTHF? Anyone? please?
Cattitude 07-03-2002 09:27 AM
sounds like the solenoid
If you had a helper it would be easier, isolate which solenoid, jump it to verify it is the solenoid, it's a very common part, should be in stock, about $20. My buddy just went thru this on his 32 Fever, changed the solenoid and bought a spare for inventory.
Good luck:D
Oh yeah- post #500- woo-hooooooo!
jdnca1 07-03-2002 09:32 AM
I had the same problem...its the solenoid. The "UP" has the blue wire running to it. As cattitude said, to be certain jump it.
CelticPride 07-03-2002 12:15 PM
Thanks Guy's
