Yellow stained bottem hull help?
What is the best chemical to use to get the yellow off the bottem, looking for something that is not like a huge smack to the face while applying, and won't mess up my alum. Trailer?
Is there something I can apply that wont allow it to yellow? |
Get "The Works" bathroom cleaner in a spray bottle.
Wet trailer down good, spray cleaner on hull and lightly scrub. A good wax puts off staining, a product called Ioso works better. Thats about all you can do. |
Power One cleans pretty good. I have also used Iron Out or muriatic acid. Some guys use toilet bowl cleaner. If you find something that keeps it off, let me know, cause I havent seen it yet.
slimy grimy works real good and is not toxic.
Slimy grimy?? Ioso??? Where to get these products
Where can I get slimy grimy?.??
And what is ioso, and where to get it? |
Star Brite Hull Cleaner worked good for me and is less aggressive to your hull than competitive acid based bottom cleaners. Put it in a spray bottle, hose off any areas around the hull ie: trailer, outdrives, wheels before you apply.
I don't know anything that will prevent the staining except consistent waxing the bottom. http://www.starbrite.com/productdeta...ull%20Cleaners |
Originally Posted by Downtown42
(Post 3721255)
Fountain of Youth - Power One. Spray it on rinse it off...
+1 for Slimy Grimy
https://www.google.com/search?q=slim...ient=firefox-a Plenty of threads on same topic in the past. Do a search for more good info. "Hull Stains" www.offshoreonly.com/forums/search.php |
Originally Posted by low_psi
(Post 3721645)
fountain of youth - power one. Spray it on rinse it off...
| All times are GMT -5. The time now is 11:30 PM. |
