Eliminate ignition keys in favor of push buttons
I have replaced basically every part on my scarab except the stock ignition key switches and wouldn't you know I am having problems with one of them! :angry-smiley-038:
Thinking of eliminating the keys entirely and going with toggles for ignition and push button for starters. When I rewired the boat I changed around the way things were wired so I don't use the acc side of the key so not loosing anything there. Anyone done this? Pro's & Con's? Thanks Jim |
I left the keys and jist added starter buttons,,i like it because i crank the engines for about 10 seconds before turning the key so the engine has oil pressure..
Originally Posted by mrfixxall
(Post 3735722)
I did it and it worked flawlessly i also added a plastic cover for the starter button in case I hit it with my knee I think I split two of the standard ignition switches before I got rid of em
not like the keys are a theft deterrent. boats are the easiest thing to hot-wire there is...except mayve riding mowers. OH RIGHT!!! SAME SWITCH!!!
Originally Posted by dereknkathy
(Post 3735956)
Originally Posted by 32hustlin
(Post 3736089)
Lol so true I saw those push button starts with the keypad locks a while ago for "security" and had to laugh I could just imagine losing a motor trying to dock and frantically punching in combinations to get it restarted
you think that's bad, try having one not restart on a twin shaft boat in a tiny little cove in front of somebody's fuel dock with 20 boats all around!! it only turns one way, and of course it is the wrong way...
(Post 3736120)
I am going to wire my ignition with a toggle and push button this winter. I like the simplicity and the looks. I will hide a secondary switch behind the dash for security.......Chances are a crook won't be able to find that, and if they do, It is insured!
| All times are GMT -5. The time now is 05:08 PM. |
