-   -   Big Metal Shavings in Drive oil (https://www.offshoreonly.com/forums/general-q/28141-big-metal-shavings-drive-oil.html)
IHTFP 07-07-2002 08:20 PM
I need some help ! I took the top cap off my 1995 Blackhawk Drive and I saw some metal shavings in the oil which were approximately 1mm X 2mm in size. Is this normal? If not, what could be wrong?
Greg
Griff 07-07-2002 09:35 PM
Definately NOT normal. Either a bearing or a gear is going bad and you caught it before the entire drive went.
