-   -   454 problems (https://www.offshoreonly.com/forums/general-q/281501-454-problems.html)
31imp 07-26-2012 01:19 PM
454 problems
I have a 31' IMP with twin 454s. One one runs great the other one backfires through the carb at about 3,200 rpms. I have replaced the carbs and jetted the new ones. I have grounded the distributor and the ignition module. I do not think there is any problem with engine itself. The distributor sensor is rusted could that have any problems?? I'm getting about 3 to 4 psi of fuel pressure. is that enough???
thanks
sac 07-26-2012 01:35 PM
I once had a keeper come out of a hydraulic lifter and it would not allow the valve to close at higher rpms so it would backfire
mr3dman 07-26-2012 02:06 PM
check your voltage, also could be a coil going bad.. swap coils and see if the trouble follows.. could do the same with the modules
