-   -   Set skrew keeps going loose on Mercrusier control? (https://www.offshoreonly.com/forums/general-q/281805-set-skrew-keeps-going-loose-mercrusier-control.html)
2Slow4me 07-31-2012 07:26 AM
I have a small set skrew (5/16-18) that holds the throttle shiffter tight. But after a short run, it's loose again.
I'm guessing it needs locktite or ??? But I know the RED locktite would make it impossible to remove.
What should I be using on this??
Thanks for the input!
This is the control I have:
http://www.mercruiserparts.com/Show_...E+CONTROL+ASSY
Knot 4 Me 07-31-2012 08:32 AM
Try blue loctite, which is removeable without heat.
mike tkach 07-31-2012 08:39 AM
Originally Posted by knot 4 me (Post 3742576)
try blue loctite, which is removeable without heat.
+1
puzzleboy 07-31-2012 09:54 AM
x2
Jay Gadsby 07-31-2012 10:22 AM
x3 :)
2Slow4me 07-31-2012 11:27 AM
Thanks guys, the blue would be more handy for other things as well. I checked the loctite site, and they also have purple, which sounds bang on for this, but nothing else.
Here is what they say, and below is a link to a handy chart as well.
LoctiteŽ 222™
Threadlocker –
Low Strength
Recommended for low
strength threadlocking
of adjustment screws,
countersunk head screws and
set screws; on collars, pulleys,
tool holders and controllers.
Also for low strength metals
such as aluminum or brass.
http://www.henkelna.com/us/content_d...king_Guide.pdf
drozz30 07-31-2012 06:21 PM
If theres enough threads just put another 5/16 set screw in right behind the other to lock it in.
Doug
1987pachanga22 08-01-2012 10:13 AM
Im sure that you probably have taken care of this but on my cable there are two set screws one from each side. If you were missing one or didn’t catch it I would imagine that you could get the same results that are fighting.
