Speedo needle bouncing..
This just started happening, the speedo needle is all over the place. Its not a GPS, I assume it comes off the hull or the drive?
Whats the solution for it? |
Is this on your Formula? Original VDO (black) guages?
Non-GPS speedometers use a pitot tube pickup to push a column of air to the speedometer head. The faster you go, the harder the column of air pushes and the higher the needle goes. There are pickups built into drives (leading edge) and pickups that are hull mounted. In either case, if the pickup leaves the water, the pressure drops and so does the needle.
The pickup for my Gaffrig speedometer is mounter to my transom, right next to the pad. In any kind of rough water, it leaves the water all the time - bouncing the needle all over the place. Other than your pickup leaving the water, all I can think of is a leak in the tubing that holds pressure for a bit, then relieves it - dropping the needle. |
I am not sure if this applies to the gauges that you have but usually if you start to see the needles bouncing or moving sporadically it is due to corrosion and or lack of ground.
I would start but checking all of the wiring leading to your gauge for either corrosion, loose wires and or positive feedback through the negative wire. I have seen this happen to other gauges on my own boat after the toggle switches get wet allowing a small amount of power to feed back into the negative wires. |
Originally Posted by Knot 4 Me
(Post 3742736)
Originally Posted by 1987pachanga22
(Post 3743502)
(Post 3743502)
I would start but checking all of the wiring leading to your gauge for either corrosion, loose wires and or positive feedback through the negative wire. I have seen this happen to other gauges on my own boat after the toggle switches get wet allowing a small amount of power to feed back into the negative wires. Here's a thought. Remove the line from the back of the speedometer. Blow backwards through the line to first make sure it's clear. (You can sometimes aspirate water up into the line.) Next, assuming it's clear, plug the other end manually and see if you have any leaks. (You can also do this by running water up the line with the speedo head disconnected, but make sure you get the water out later.) Finally, blow into the back of the actual speedo and see of the needle bounces at steady pressure - which could mean a ruptured diaphram. |
Pulled the tube and water is running out of it.. Looks like it got into the back of the speedo too.. dangit!
Originally Posted by waterboy222
(Post 3744439)
| All times are GMT -5. The time now is 03:17 PM. |
