Originally Posted by Budman II
(Post 3744207)
Were these run in salt water? If so, I am with derek - you need closed cooling.
Originally Posted by Fenderjack
(Post 3744487)
How long were those on to get that? Also they do make flushing kits to help
John jr |
Boy, I think those are the worst I have ever seen around our area. :( :( Usually they just get eaten up around the passage to the intake manifold. I know of several guys running aluminum heads in the same water and they are not having problems like that ? I will say that I think the Potomac and bay water is worse than ocean water as far as corrosion. Must be just the right mix :(
I mainly wanted to reply to your comment:
Originally Posted by My Addiction
(Post 3744096)
At the front of the motor there are no water passages into the block from the head,(why is this) so the it seems the water and whatever debris is in it just sits there and eats the aluminum.
What would happen if I just added(drilled) my own water passage to let the water flow into the block. Bill Koustenis Advanced Automotive Machine Waldorf Md |
Thanks for the refresher on the flow Bill- was trying to remember how that worked...I get the intake passage corrosion issue as well.
Don't see you much over at the Camaro site anymore...of course not a lot going on I suppose... Lane |
Closed cooling would fix this... rather inexpensively considering.
I ran in salt with my aluminum head small blocks and never saw anything like that. My heads weren't anodized either. |
| All times are GMT -5. The time now is 03:09 PM. |
