-   -   aeromotive boost referenced regulator hanging up (https://www.offshoreonly.com/forums/general-q/282018-aeromotive-boost-referenced-regulator-hanging-up.html)
ezstriper 08-02-2012 09:48 PM
With my procharger system, run aeromotive A1000 and their matching carb boost referenced regulator, issue I have is the fuel pressure comes up perfectly with the boost, but does not return back unless you shut pump off ?? so after a hard run running 14-15 psi, come down off plane, boost at 0 fuel pressure stays at 14, floods carb...boost picked up off carb box, boost gauge t-ed off that line so both seeing same thing...aeromotive says should not be doing it...done it since parts were new...been having to shut pump off everything you back down...they said fuel pressure should follow boost exactly...not mine...thanks Rob
