bravo 1 reservior hose connection?
Where does the gear reservior hose connect to on the inside of the transum for a bravo 1? I have a barb hose fitting to the left of the cooling water intake hose ,, which looks to be the place. Just wanting to make sure.
Small barb 'could' be the speedo tube?
it's just above the shift cable, and has a e-clip that holds
it in |
Originally Posted by JaayTeee
(Post 3747436)
it in [IMG]http://i388.photobucket.com/albums/o...1/IMG_1124.jpg[/IMG] |
The bronze barb is it. Thats the old style, not the plastic one with the e cllip.
You should consider sealing the wood at the drive cutouts. Gelcoat is easy...
Originally Posted by bowtie
(Post 3750541)
Originally Posted by BenPerfected
(Post 3750643)
Just an fyi, your speedo is the hex connector top right under the yoke
Originally Posted by mr3dman
(Post 3750735)
| All times are GMT -5. The time now is 06:18 AM. |
