-   -   questions re adding a fuel water separator (https://www.offshoreonly.com/forums/general-q/282412-questions-re-adding-fuel-water-separator.html)
Sledge Hammer 08-08-2012 01:45 PM
My boat is non stock and has been running without a fuel water separator for some time. I am replacing the fuel pump and have decided to add a fuel water separator. My question is does it plumb from the tank to the fuel water separator then from there to the pump?
tunertech 08-08-2012 01:59 PM
tank, filter, pump
Sledge Hammer 08-08-2012 02:05 PM
That's what I thought. Thanks
stevesxm 08-08-2012 05:01 PM
Originally Posted by tunertech (Post 3749263)
tank, filter, pump
you sure you want to be sucking thru that filter rather than pushing thru that filter ? thats not how i would do it nor have ever seen from any factory installation...
mike tkach 08-08-2012 05:24 PM
both of my performance boats came from the factory,tank filter pump.
wexrocks 08-08-2012 08:37 PM
all factory setups should pull thru, not push thru. if they don't, they were changed. pulling thru allows the water to settle, pushing thru continuously stirs it and forces particles thru the micron filter.
stevesxm 08-09-2012 05:34 AM
hmmm. oh well... i guess that must be correct. my boat wasn't that way at all.
sorry. carry on.
addendum... i i admit to being obsessive... and discovering that i am factually wrong about something that i believed to be true sends me off to find out why... so i called engineering at racor and asked them this question. and it turns out for sure these filters go before the pump. the resons are that they are designed specifically to work on the suction side ( low resistance because of low viscosity and because if water passes thru the pump first, it emulsifies and is then difficult to seperate...
how about that. interesting.
