-   -   best shift cable bellows (https://www.offshoreonly.com/forums/general-q/282652-best-shift-cable-bellows.html)
zeke 08-12-2012 02:55 PM
who makes the best shift cable bellows?
Is there any aftermarket ones made out of a better material?
I got a remanufactured HP transom assembly from vinzi marine in florida and my shift boot is leaking already in only about 30 hrs. Im pretty sure he used the cheapest one possible as he built a very poor transom assembly.
zeke 08-14-2012 08:14 PM
im guessing i should buy the merc one?
Port Monster 08-14-2012 08:31 PM
I am no expert but you generally get good quality with merc. If I didn't see anything that looked better then my default would be Merc.!
zeke 09-01-2012 10:54 AM
Anyone know where to buy the tool to clamp the little steel clamp on the bellow?
Alex 09-01-2012 02:47 PM
You can substitute the steel clamp with one or two tie wraps instead.
Don't pull them to hard though, it is good if the bellow can slide on the cable with some friction.
bowtie 09-01-2012 08:52 PM
I usually throw that steel clamp away, use a tie instead. As far as quality, Merc bellows are the best fit and last longer than any aftermarket bellows.
zeke 09-02-2012 09:05 AM
I bought the sfift cable kit from CP not sure what kind it was but i wanted it fast thats why i went threw them
