I appreciate the attemps of hope. My father said its possible that the timing chain broke and locked it up. I dunno I will pull it and report back
I FEEL YOUR PAIN, I DROPPED MY ENGINES OFF THE END OF FEB I GOT NOTICE THE FIRST OF AUG THERE DONE:eekdrop: AND OVER MY BUDGET, THE ECONOMY IS BAD CANT SEEM TO GET MY DUCKS IN A ROW. SO MY FOUNTAIN IS DOWN TILL NEXT SUMMER:(
A little update. Motor is out as of today and you can defiantly tell the crank is broke. It will be torn down today for damage assessment
Thanks for everyone's help |
Originally Posted by Ntrsspray
(Post 3758711)
Thanks for everyone's help At least its not lonely mines at Wazzup. |
What happened. Heard you were towed
Originally Posted by Expensive Date
(Post 3758789)
(Post 3758894)
Turns out I have a pinhole in the cylinder head, Smitty says its weird because the engine does not have a lot of rust in it. Not sure if I am just getting new heads or just repower with the 400 HP 383s that Mercury has. Just don't want to fix one motor and then the other one goes in the spring. Also would see a nice MPH increase. But if I do this I guess I am keeping the boat for a few more years,but if I can see 80 which is a realistic number I'm ok with that. Just waiting on prices for new motors,will no in the morning. |
Originally Posted by prostock85
(Post 3759103)
If you need a ride for the fall run, your always welcome.
Bummer man....i finally got my answer i was dreading. Balancer sheered keyway, broke crank, broke block, broke one rod, need a cam and god knows what else
im sick to my stomach |
Yep a bummer for sure...good luck on the rebuild
| All times are GMT -5. The time now is 06:26 AM. |
