-   -   how much is this gonna cost me!!? broke again (https://www.offshoreonly.com/forums/general-q/282941-how-much-gonna-cost-me-broke-again.html)
dsmawd350 08-16-2012 02:31 PM
think this happened when i got caught up in a tight area on the trailer dropped it off the edge of a drive think the nose cone bottomed out on the concrete. didnt realize it happened and ive been out twice since. trim gauge quit working since it happened.
so what exactly is it thats broke. can i pull the outdrive and transom assembly and have it welded. does it need to be fixed immediatly?
http://img.photobucket.com/albums/v6...57-08_2381.jpg
http://img.photobucket.com/albums/v6...-56-47_468.jpg
searaycer 08-16-2012 02:45 PM
Time for a new gimble at least.
drpete3 08-16-2012 02:53 PM
pic is hard to see but did you take a chunk out of the helmet? Thats what it looks like to me. if so you need to replace it becasue if it goes there is a chance the rest of your drive will be at the bottom of the lake.
drpete3 08-16-2012 02:54 PM
new helmet about 900 from merc and I would expect that much in labor too.
1BIGJIM 08-16-2012 03:16 PM
The bell housing/helmet broke off at the hinge pin.
It's a couple hour job if you have the tools.
Remove drive. Remove 2 hinge pins. Undo bellows/shift bellows and cable. Replace with new housing. Your trim switch will work after you get this replaced.
Do not take this on the water like this. Like said above, drive might sink to bottom along with the boat. Water comes in fast when no drive shaft is in the gimbal bearing.
dsmawd350 08-16-2012 04:44 PM
ok thanks for the help guys ill add that to the list of things to do on it haha
Jeff P31 08-16-2012 06:08 PM
Had one break like that on my old chaparral I had . the drive will NOT sink to the bottom because the trim cylinder's will prevent that but when the bellow pulls off which it will the boat will go to the bottom . been there !!
FIXX 08-16-2012 08:37 PM
fixx
I M me,,,i have 2 of them that i can part with..
sanderps 08-19-2012 10:47 PM
Just got my boat back from the marina from the exact issue and it cost me 3800.00. I also replaced the gimbal ring though.
Griff 08-20-2012 12:49 AM
Call your insurance company
phragle 08-20-2012 01:26 AM
quick search...ebay bravo helmet $250
Borow a star socket from buddy $0
new bellows, gimble bearing ec $300
Case of beer to bribe buddy
into helping $25
skinned knuckles etc.. $0
misc bull**** $100
Total.................................. $675
plus an afternoon.
phragle 08-20-2012 01:27 AM
Did they kiss you first or at least us a little lube???
dereknkathy 08-20-2012 06:13 AM
i can't tell. is this bravo or alpha? if alpha, prices are even better than phragle's quote. lots of used alpha parts out there. also add shift cable though...
dsmawd350 08-20-2012 11:12 AM
Its a bravo. Me and my buddies are big gear heads so were gonna tackle ut ourselves he actually owns a welding and chassis shop building race cars. Would it be possible to fix the part by tig welding hea easily the most competent welder in my area. Also anyone know .of a write up or mind briefly giving.me some instruction. Gimble bearing a must? I just replaced it
