Need speed under 10k
I have a 257 carrera deck boat stock 454 efi runs 55 mph and i would like to run 70 to 80 i have 10k to spend any suggestions ?
:angry-smiley-038::lolhit::daz::poopoo: add 50K
IF I HAD 50K I WOULDN'T NEED SUGGESTIONS BUT THANKS :thankyouthankyou:][/B]
share some of the details regarding the boat. I reworked a NeXt this spring 28 footer with a 509 CI and shorty drive when it left it was 85 GPS. Owner was very happy. However, it was over 10K close to 12K when done.
What do have to work with? |
M3 Pro charger with match prop for the new power...??
It might be around 70. |
Originally Posted by KITCHENSKARS
(Post 3755797)
Originally Posted by 92nsx
(Post 3755869)
m3 pro charger with match prop for the new power...??
You would need somewhere in the neighborhood of 200-300 horsepower to move from 55 to 80. Heads, cam, exhaust, gaskets, computer tune... seems like that would kill 6-7k easily. Add another grand for a new prop. I'm guessing low to mid 60s could be had for 10k. Will you pull the engine and do all the labor? The first 100 horsepower could happen in your price range. Assuming you have a Bravo 1? I don't believe Mercury puts this drive behind anything over 425 h.p. That may also be an issue. Good luck.
To safely run 70+ mph you really need full hyd steering. That will take more than half of your 10k, then you will need a bigger prop, then you will need to upgrade the drive to handle the added HP.........then, etc........
