-   -   boat difficult to drive at speeds over 35 mph (https://www.offshoreonly.com/forums/general-q/283044-boat-difficult-drive-speeds-over-35-mph.html)
sanderps 08-18-2012 09:20 PM
I have twin 502 mags with bravo one drives and 26 pitch 4 blade props. Once I get the boat on plane it wants to dart one way or the other with little to no steering wheel input. As you can imagine, this is not fun. I haven't been able to get the boat over 45 due to the unstable ride. Any thoughts? Thanks. My boat is a 28 foot obsession with two steps in the hull.
Have only owned the boat for a couple months.
Fenderjack 08-18-2012 09:25 PM
Do you have external steering or the tiller steering.If you have full hyd external steering I would check the alignment off the drives one to the other. If it is inside tiller steering it could be slop in the tillers,Do you have a tie bar? JOHN SR
FIXX 08-18-2012 09:42 PM
da trim da trim boss,,your not trimming the boat enough,,need to get the bow out of the water..you are bow steering the boat..if you havnt driven a boat with steps and twins have someone teach you..also watch how you make turns or you may spin out,,also ware your tether...
sanderps 08-18-2012 10:19 PM
Full external hydraulic steering with tie bar.
FogduckerIII 08-18-2012 10:32 PM
Your not hearing/reading the good advice given...:whistle:
sanderps 08-18-2012 10:56 PM
I agree with the advice given above. My problem is that I drove a fountain with the same setup as mine and the boat drove like a dream. No issues whatsoever. The owner of that boat then drove mine and he couldn't keep the boat from darting left or right or even porpoising.
4mulafastech 08-18-2012 11:39 PM
If you can grab the tie bar and move the outdrives at all there is air in the hydraulic steering system. Also check drive alignment.
Fenderjack 08-19-2012 02:07 AM
All this sounds like a alinement issue or trim issue. If the drives have no slop in them, then it would seem the boat is being trimmed bow down to much.
John jr
JETDOC 08-19-2012 12:36 PM
Are your trim tabs stuck or placed down?
