-   -   Anyone use Lightning High Performance Ant-Reversion Cams? (https://www.offshoreonly.com/forums/general-q/283504-anyone-use-lightning-high-performance-ant-reversion-cams.html)
My Addiction 08-25-2012 10:50 PM
I am currently putting a bbc 555ci n/a carb gen 4 motor together. I came accross these cams on CP Performance web site http://www.cpperformance.com/c-1501-...sion-cams.aspx. I run the KE aluminum long manifolds. Im not sure if I would even need the ant-rev cam.
Is there some wierd installation process. I allready have the 9 position timing set.
I am thinking of running the stage 3.
Any input would be appriciated.
picklenjim 08-26-2012 01:30 AM
Their just saying you will need the 9 position timing set in order to "degree or sync" the cam with the crank for proper installation of it.
