-   -   Fuel Pump Kill (https://www.offshoreonly.com/forums/general-q/283535-fuel-pump-kill.html)
smcser 08-26-2012 05:00 PM
Fuel Pump Kill
What would be the best way to wire an electric fuel pump when the engine is shut down? Threw lanyards or relay?
FIXX 08-26-2012 05:04 PM
fixx
oil pressure switch to a real heavy duty relay..like a western snowplow solenoid..
articfriends 08-26-2012 05:41 PM
"hobbs switch" (oil pressure switch) to a nice relay-bingo!
Rookie 08-26-2012 05:57 PM
Here is the best pricing I found.
http://www.amazon.com/Mr-Gasket-7872...+Safety+Switch
protechcoat 08-26-2012 10:22 PM
hobbs switch is the best way to control fuel pump .also a fuel return from the regulator to the tank helps too.
ezstriper 08-27-2012 06:14 AM
need to run power thru a relay, but I like to use a push/pull switch mounted at dash as a emergency/security override in between ignition and pump...
