Too hot? 454/Bravo running over 240F
you can check sender with ohm meter(0-90) hooked onto sender in hot cup or pot, same with t-stat. normally when guage acts up on panel it will have partner guage to act up also, so check grounds and power connections on guages.
Overheat
I agree with MOP. Not only check for grounds at dash but also on the engine as well. Computers do not work well with corroded wire terminals. If that is good then maybe check your sendeds and gauges. Ground out the sender on the engine and check gayge for pegging to high side. If not then it could be bad wiring, bad sender or a bad gauge. If u still have problems, e-mail me
It was partially blocked and a wet day in the UK plus it was a plonker http://www.offshoreonly.com/forums/i...es/whistle.gif moment
Guess if you drove it long enough, the motor would have cooled down just by all the water surrounding it.
