High Oil Pressure from Mercury 377 Scorpion Engines
I recently purchased a used boat with twin Mercury 377 Scorpion Engines with approx 200 hours on them. I noticed the oil pressure on both engines run approx 75 to 80 psi at 3,000 RPM. Is this normal for these engines?
It seems a bit high as I'm used to the Mercury 454s. Also the boat has new Livorsi guages thru out. Does anyone have any experience with these engines? |
Are you sure you have the correct ohm senders for the new Livorsi guages????
How would I go about determining the correct ohm senders for my gauges? I have very little experience with installing gauges.
Fixed - wrong sender - thanks Griff. |
| All times are GMT -5. The time now is 06:09 AM. |
