Friend of mine has a trams am with a ls1 with head and cam package makes roughly 550 on the Dyno
Originally Posted by bor I build a ls 2 into marine version ,got a new l 76 truck engine from the newer trucks which is a ls2 block whit ls 3 heads on it and a high truck intake ,making 360 hp We stroked that whit a compstar kit to 408 and upgraded the valve train ,timing gear and put in a bigger cam and a ls2 intake to get it fit under the engine hatch and maked it dry sump whit ls 7 oil sytem ,cooling sytem I used from pcm . The headers I dyno whit where cmi s but there high and didn t like the collector so switched to a set lightning . It make s 560 hp @6100 rpm and max tq is 550 ft lbs @4700 and tq is real flat from 3000 -6300 rpm above 500 ft/lbs know have 20 hrs of use and like it every time if I go out ,this engine push real good and screams for more ! here are some video s ! http://www.youtube.com/user/phantomlspower?feature=mhee enjoy .so far 96 mph but still testing props and spacers . Holy chine walk batman !! http://www.youtube.com/watch?v=3eSMSJrJ3bk&feature=plcp @ about 1:52 |
Originally Posted by ICDEDPPL
(Post 3777339)
Now have a -3" imco sc drive on it and handles like a dream ! Also on one video it go s complete on one side (rub rail hits the water ) due to going of the throttle before trim it back first . The cam specs I don t no have to ask the builder . |
Why the switch from the black hawk?
Originally Posted by professor_speed
(Post 3777620)
Another downside is that it goes very fast on idle and also my engine idles at 900 rpm and the blackhawk don t like to get both props moving at that rpm it gives a very loud bang ! So I decided to try a imco which also gives a lot beter prop selection ,I would loved to try a set 31 props on the BH but there very rare and espacialy here in europe . going out today whit a 1" spacer on the imco to look if I can get the hull a little more out of the water and gain some speed . |
I figured that. Looks like your inner lifting strakes go all the way back. Great set up either way
(Post 3777857)
Thx !! Yeah your right had thinking to shave them of the last 4 ft but after all the work I had to get it this far I skipped that idear ! Have to be satisfeid one time it runs great even at 96 here a pic when I started whit the hull , http://i1007.photobucket.com/albums/..._01/p21004.jpg http://i1007.photobucket.com/albums/...001800x600.jpg |
| All times are GMT -5. The time now is 07:46 AM. |
