trying to get 700hp from a talldeck 540 >
Old 09-06-2012, 08:03 PM
Originally Posted by johnnyboatman
Yes i was paying for 700hp and got 620hp
That is a bummer, no doubt about it, what did your engine guy say???
BBCLiberator is offline
Old 09-06-2012, 08:32 PM
502 +.030 =510 -9.2:1-dart 320 n0 port hvh intake at lest a 680 lift cam spin 6000 = 715 HP )
happy is offline
Old 09-06-2012, 08:55 PM
GPM
So what model Brodix heads, what are the flow numbers ? what intake ?
GPM is offline
Old 09-06-2012, 09:24 PM
X2
And who selected the parts? Specifically the cam, heads, and intake?
cubicinches is offline
Old 09-07-2012, 10:16 AM
johnnyboatman's Avatar
i purchased the heads off of here, the came off some 580ci engines , the builder chose the cams and intake. YES IM THINKING A BIGGER CAM IS WHAT IT NEEDS, THEY GOT IT SET UP FOR REALIABILTY, I NOTICED ALOT OF ADVERTIESERS LISTING WITH THE SAME POWER.
johnnyboatman is offline
Old 09-07-2012, 11:18 AM
Yeeeeeeep! Sounds very close to my set up. Not the best at the dock, but sounds mean and runs even meaner. I have AFR's, a little less lift and a little more compression.
Cobra100+ is offline
Old 09-07-2012, 04:31 PM
GPM
Being from a 580 means nothing, need to know what the heads flow at what lift to know what the intake needs to flow to accommodate them. Then you could pick a cam that would work best for your application. You may want to consider the Comp Xtreme.
GPM is offline
