-   -   neautral safety switch in controls? (https://www.offshoreonly.com/forums/general-q/284182-neautral-safety-switch-controls.html)
26sonic 09-04-2012 08:51 PM
have a single 1999 502 mpi engine keikefer controls ( sep gear shift/ sep throttle boat. all of a sudden in neatral boat won't turn over like the battery is dead no sound at all. what should i check to verify the switch is bad ? should my gauges still be reading ? and can i temp. by pass it to check ?
Griff 09-05-2012 01:46 AM
Move the shifter back and forth a 1/2 inch or so while turning the key.
It can easily be bypassed. Just remove the 2 wires from the Neutral saftey switch and connect them together.
dereknkathy 09-05-2012 06:20 AM
go to starter solenoid and jump it. if it cranks, then there is a problem upstream. if no crank, start with engine end. battery first, then alla grounds, then solenoids...
26sonic 09-05-2012 08:20 AM
if the switch is bad should any of my gauges be reading ? fuel gauge etc. ?
mike tkach 09-05-2012 08:36 AM
with the key in tho on position,gauges should work and alarm should sound,if not,the problem is not the neutral safery switch.
92nsx 09-05-2012 02:59 PM
You are on the right track. My baja did the same thing last weekend. I poked my head under the controls and one wire magically was off the switch. Plugged it back in and I was in business.
Griff 09-06-2012 02:23 AM
Yes. All the neutral saftey switch does is prevent it from starting in gear. It sounds like you have a problem with the kill switch, ignition switch or the main engine breaker popped.
