496 HO Cranks but wont Start
I have a 2003 496 Ho that has a problem starting. Everytime I take it out, it takes forever for it to start at first. It Cranks and Cranks but wont fire.
Sometimes after I run it for a while it fires right up. But sometimes it won't unless I crank it for a while. Boat seems to run fine once started its just the initial firing that seems to be a problem. I took it to a well known shop and it does not show any codes and they replaced my low pressure fuel pump for $400.00 and it seemd to work good for about a half a day then the same problem again. I'm afraid I'm going to burn up my starter, you can hear the bendix slip out on it now. Any Suggestions? |
are your pumps priming?
Investigate the fuel pressure regulator....:bunnydance:
| All times are GMT -5. The time now is 04:39 AM. |
