Using 4 blade SSM III or IV props on a SSM II
Here is my situation. My boat has SSM II drives on it now. The props are 15x23 3 blade cleavers. Labor day weekend I bent the ear of one of the props and Johnnys prop shop in Detroit says they cant fix it, it is too thin. From what I have been reading my props are a 19 spline small shaft similar to the shaft in a SSM III. Will 3 or 4 blade props off a SSM III fit on my drives? I believe they are both 19 spline and 1 3/8 dia shafts
They will fit the shaft but not fit the application. Most of those drives were mounted pretty deep and need that small diamter/thin prop. If you had the bigger props trimmed they would work. But I would not run a 4 blade as they are harder on the drive.
Honestly dude, I would yank the ssm ii's off, and bolt TRS on the boat. Get yourself some bravo/trs style 4 blades. The boat will probably run alot better.
Check ebay for some small shaft, small diameter cleavers for the ssm ii. Ive seen them on there quite a bit. |
Originally Posted by MILD THUNDER
(Post 3775290)
| All times are GMT -5. The time now is 04:11 PM. |
