-   -   Crower s-steel rockers help!!! (https://www.offshoreonly.com/forums/general-q/284752-crower-s-steel-rockers-help.html)
catman01 09-13-2012 09:47 AM
Anyone that has experiences bad or good with the Crower S-Steel please post your experiences as I am considering them for my engines as the T&D aluminum keep failing. Thanks in advance for the input. Rob
bcfountain 09-13-2012 10:55 AM
I have had a set going on 8yrs now.no issues.good rockers but pricey.
Trash 09-13-2012 11:01 AM
I wanted to run the Crower stainless but they exceeded the budget. I'm running Crower aluminum rollers and they've got about 70-80 hours on them without a problem so far.
catman01 09-13-2012 03:13 PM
bcfountain, are they the shaft mount or stud mount that you are running?
CC230 09-14-2012 06:15 AM
I have them on my BB Chevelle. They used to have almost 600#'s of pressure open wilth a solid roller. That was from '99 to '05. Now the cam is a hydraulic roller, 460#'s open.
Same ones, no issues, street car. Only one had a bad bearing, got metal in it, still rolled ok but was blue. (solid roller broke)
My small block I'm building for the boat will have them.
FWIW.
bcfountain 09-14-2012 07:33 AM
Stud mount
catman01 09-17-2012 10:45 PM
The stud mount seem to be proven. I am looking for more info on the shaft mount!
ThisIsLivin 09-18-2012 09:59 AM
I have a set on my 524 that have 150 hours on them and I have a 6000rpm rev limiter that I hit more often than I should with 425lbs open pressure. Just had them checked last year, still like new.
CC230 09-18-2012 02:27 PM
Sorry, stud mont on the car.
