-   -   Small block Chevy cylinder head ID (https://www.offshoreonly.com/forums/general-q/284753-small-block-chevy-cylinder-head-id.html)
84 Scarab 09-13-2012 09:48 AM
Anybody have a way to id which cylinder heads I have? I got a pair of heads(for free) off a mid 90s 5.7 mercruiser, they are the centerbolt valve cover type. I am wondering if they are the Vortec heads and if I could use them on my older merc 260 to increase power? What numbers or casting marks should I look for?
befu 09-13-2012 10:10 AM
look at the combustion chamber, very easy to tell. Lots of pics online on how to tell. Also saw tooth castng marks on the end of the head.
Yes you can use them on your older merc 260's, if they are vortec it will require new intake manifolds. and the vortec gasket sets are about $100 more than the standard old school chevy stuff.
Brian
87MagnumII 09-13-2012 10:17 AM
Pull the valve cover and find the casting number in the oil return. If it ends in 906 or 062 they are vortec
gmhdfan 09-13-2012 09:48 PM
Do the heads only have 8 bolt holes to mount the intake? Vortec heads don't have bolts in the center of the head like other SB heads.
dodgezilla04 09-13-2012 10:49 PM
Vortecs do have center bolts just drilled at a different angle
gmhdfan 09-13-2012 10:55 PM
Those are the earlier throttle body heads off a truck.
84 Scarab 09-14-2012 09:02 AM
I remember seeing 007 stamped in the top of the head, under the valve cover. I also remember there are 2 bolts in the center, between the intake ports, on each side. I don't have them with me I will report back with more info when I get it.
BillK 09-14-2012 09:04 PM
Not so,
Vortec heads only have 4 bolts for the intake.
dereknkathy 09-15-2012 02:22 PM
2 center bolts at diff angle than end ones? they are TBI heads. they will work, but have no real perf value. also you hafta either get an intake manifold that matches them, or butcher an old style one by cutting the 4 center bolts into slots to mount center bolts. they were free. go get 8 cents a pound for them and put towards a set of vortecs or Darts...or beer...
