what starter for larger cubic inch?
I have a merc hp500 starter got it hot, had it rebuilt at a local shop lasted 8 bumps of the key and blew the drive. I heard they probably use chinese parts. I have the big teage pan on my 572 so starter change is not easy.
what starters are you guys running? I found this: http://www.cpperformance.com/p-13381...r-sbc-bbc.aspx |
the other issue i just realized while searching is im staggered bolt pattern.
Tilton makes both
Powermaster
http://www.powermastermotorsports.com/ |
fixx
got one in my donzi for the past 12 years..i have about 6 junk tilton starters i can send you if you think you could mak one from the 6 i took out of the race car a few seasons ago.. i believe your block should have both style bolt patterns.. |
check out Db Electric
I run a mini from Db Electric from ebay on my motor because of the kick out in my pan. I was concerned about the parts in it...mainly weather it had steel gears in it or not. So I emailed the owner of Db and he promptly responded that it does use steel gears. Which sold me on the starter. Very reasonable at $105.00 also. Works great!
I replaced my merc starter with a powermaster 2 years ago. Spins a 582ci quite fast. And my engine isn't the easiest to start.
http://www.powermastermotorsports.com/250_ft__lbs_.html |
My Tilton starter would not work with the oil pan I had on my sbc race car. This starter cleared the pan and headers and has great cranking power.
http://www.msdignition.com/Products/...red_Mount.aspx |
Originally Posted by mustangmark
(Post 3778139)
Then this summer my DB starter began making a grinding sound. Found out that the cheap Chinese bolts they sent me had bent. Installed a set of Grade 8 GM bolts, but was still getting grinding noises. Replaced DB starter with a Merc starter, and problem was eliminated. I know many are running these without problems, but this was my experience with them. And as you well know, starters are not a lot of fun to replace when you are out on the lake! |
Are you guys using nonmarine starters?
Originally Posted by zt260
(Post 3778281)
fixx
Originally Posted by zeke
(Post 3778530)
I emailed these guys and they don't make a marine version
(Post 3778525)
It may sound silly but I haven't looked to see what the factory starters are on my HO's, but they don't sound like the truck version. If you were willing to use as non-marine starter, I have had GREAT luck with 04-up 8100 starter. Used it on my 16:1 522 in my mud racer, never a whimper in that slop for the 6 years I was into that.
(Post 3778530)
Hands down the best starter right here, we had quite a few boats, some blower motor, some N/A and we could not keep starters in them. These Hitachi Starters are KILLER and very low profile and can honestly say we have not had any issues with these.
http://www.competitionproducts.com/H...uctinfo/PE106/ |
I found a 3hp, 4 gear reduction mini starter works good for my 496 stroker
| All times are GMT -5. The time now is 12:04 PM. |
