-   -   Weiand superchargers (https://www.offshoreonly.com/forums/general-q/285465-weiand-superchargers.html)
dcb 09-26-2012 07:32 AM
Who is everyone using for the 575sci supercharger rebuilds? I have two Weiands with about 260 hours on them, and I want to be proactive and have them checked/gone through over the winter.
Need4SpeedGTCS 09-26-2012 09:18 AM
Yeah, good luck with that!
Sorry for the sarcasm but after one of mine failed this year it's been nothing but a pain in the azz trying to locate parts/reliable service. Apparently now that Holley owns Weiand and B&M they have pretty much shelved the roots style blowers. Jeggs and Summit still carry them for automotive but don't offer service that I know of.
So, after having to end my season early, I'm replacing both of mine with Whipples. Twin screw units are more efficient, more reliable and IMO the way to go.
p.s. come spring I'll have the old blowers (one bad), intake manifolds and throttle bodies up for sale...or for donation to a maritime museum!
1 MAIDEN AMERICA 09-26-2012 10:24 AM
I've got 340 hours on mine. They have front and rear oil sumps. I've replaced the bearings and seals twice and all has been good. It's pretty easy. Just put everything back where it came from. Mark the rotors, timing gears and shims. I don't even pull the throttle bodies.
When The Blower Shop finally gets a snout for their replacement 575 blower I'll buy them. They're supposed to be better. Funny part is that their rear bearings are greased like the 575 blowers that fail all the time opposed to being in an oil bath like mine that have prooven to be better.
Rookie 09-26-2012 12:29 PM
DMPE Give Brian a call.
http://www.dmpeinc.com/superchargers/
4bus 09-26-2012 12:41 PM
Originally Posted by Rookie (Post 3784768)
+100! Great people, they are getting mine soon, doing bearing cage upgrades and adding Teflon strips to the rotors. The Teflon can add 2 psi of boost without spinning any faster
He spent 30 mins on the phone with me, they know these blowers well.
dcb 09-26-2012 04:32 PM
Thanks for the info 4bus, did they give you an estimate?
4bus 09-26-2012 05:41 PM
He told me if I had to do everything, new bearings and all I was looking at 1500 for both with Teflon. However, I only have 60 hrs on them so we will see what they look like inside.
Also depends on what generation blowers you have, the later ones need more mods to prevent failure. I have the first gen.
Give them a call. Parts are relatively inexpensive, and he will talk you through all options and why they ate needed or not. They know their stuff
dcb 09-27-2012 06:32 AM
I have one of each, prices seem reasonable, thanks alot for the info.
dcb 09-27-2012 06:58 AM
I also read somewhere here on OSO that dustin whipple said that teflon strips on a 256 marine blower was not a good idea - why?
Here's Johnny 09-27-2012 07:29 AM
Originally Posted by 4bus (Post 3784775)
+100! Great people
X2.....they did both my blowers last winter and did all the mods.....ran great all season...... 2nd time I went through these blowers and both are still in great shape because of that.......I have the older(better) style front and rear oil bath...... price was very fair also........
4bus 09-27-2012 08:26 AM
They do not do a total seal strip job, as you would on a drag car. The blower will still spin free by hand, however the are lowering the tolerance between the rotors and the wall increasing boost and windage.
Making the blower moree effecient at the same rpm is the ticket IMO
4bus 09-27-2012 08:27 AM
Me too, which also means I have the old headgaskets.....which is the primary reason mine are coming apart this year.
Have you been inside your engines yet?
Here's Johnny 09-27-2012 09:07 AM
Yes I did......complete rebuild from top to bottom...... here is a link to a thread I started after the rebuild was complete. It will give you a breakdown of what we did......
http://www.offshoreonly.com/forums/g...haul-done.html
dcb 09-27-2012 09:25 AM
I understand - makes sense, thanks for the info.
