X dimention on straight v
Guys need some input. I have a 28ft conventional v. Boat will have a single big block. Not sure where to set x. I'm getting mix answers. Some say prop 2-21/2 below bottom an some say 3 1/2-4 below. The hull is the cig mold.
Thanks ron |
Originally Posted by T-Mone
(Post 3785634)
Thanks ron |
what drive? if it's a std. length bravo with 500 -700 hp than 17" would be a good start. I guess the question is what was the X and shaft depth before the re rig?
Originally Posted by IRONMAN
(Post 3785656)
For reference, 28 Panteras are set at 17-17.5 and that puts the propshaft about 4-4.5" below the bottom
you can get spacers to put a bravo deeper. so i would consider going a little higher. start at the top and make sure everything fits under the hatch first.
ok thanks for imput. gonna cut hole today. im gonna do 17 3/4 should be safe at that. when i did my carrera i put prop 2 1/2 below an if i ran a 4 blade no diffuser ring it was a ***** to plane off.
I wouldn't go higher than 17" and check the bottom see how much rocker or hook it has. If it has none go 16" to minimize porpoise.
