-   -   Did I burn it up??? (https://www.offshoreonly.com/forums/general-q/285605-did-i-burn-up.html)
Fastereddie 09-28-2012 07:42 PM
Did I burn it up???
Just replaced my Bravo sea water pump and in my haste I connected the hoses backwards......stupid,stupid,stupid...arrrrggg. I ran it at idle for about 2-3 min. before I realized what I had done. My question is, do you think I just ruined it?
P.s. it was lubed with a nice film of grease when assembled.
blownhammer2000 09-28-2012 07:45 PM
2-3 min is a long time time, 30 sec maybe, i would take it out and check it out real good just to be sure, better safe than sorry
250 sport 09-28-2012 08:53 PM
All lubed up it might be ok. Will it pump water?
However That is a long time, it might be best not to chance, that's your call.
johnnyboatman 09-28-2012 09:11 PM
well ive done it before and mine ran fine afterwards.
Fastereddie 09-28-2012 09:15 PM
Well, everything looks to be ok. Lots of water flow, working good. 👍
Off to the lake in the morning.
phughes69 09-30-2012 10:25 PM
Carry a spare or two and learn how to change it on the fly. I learned the same lesson also. I was running my boat on the trailer with one of those toilet plunger looking things pressed up against the thru hull water inlet. Dam thing could not seal at all (even with grease). I wound up toasting a impeller. Decided to replace both of them. I now have 2 spares and all the tools already set aside to do one "just in case" one goes bad.
