454
can anybody tell me why or what would cause an exhaust valve to break? my buddy has a very mild cam, nothing extreme, roller rockers and pro topline heads this is the second time this has happened to him, and both been exhaust! any info would be apreiciated!
What kind of valves are they? If they are the ones that came with the heads, then they are probably just a standard grade stainless valve. The longevity of these valves in a performance marine environment would be sketchy. If you are planning to lean on the engine at all, or even like to do the extended 3800 - 4200 RPM cruises on a regular basis, then you would be well served to install a set of the inconel alloy valves by Manley, Ferea, et. al. Exhaust valves tend to get very hot in a marine engine due to the extreme loads these engines see.
Also, ensure that there is adequate valve to guide clearance. Double check the jetting on the engine to make sure it is not running lean. Lastly, pressure check the exhaust system to ensure that you are not leaking water back into the cylinder. Cold water hitting a red hot exhaust valve leads to premature failure of the valve in most cases. |
Originally Posted by Budman II
(Post 3787634)
Also, ensure that there is adequate valve to guide clearance. Double check the jetting on the engine to make sure it is not running lean. Lastly, pressure check the exhaust system to ensure that you are not leaking water back into the cylinder. Cold water hitting a red hot exhaust valve leads to premature failure of the valve in most cases. And be sure you are running at least a 110gph fuel pump. |
Was the stem bent like it hit the piston and then broke? Or was it a clean break? I was talking to somebody about this the other day. And recently they saw the same thing happen to a Ferrea inconel exhaust valve. I believe it is at Ferrea at this time being examined. Head broke off of the stem with no contact with the piston.
Also what Generation block is this? I had troubles with exhaust valves sticking in the guides when I changed heads on my GenV blocks. I had to plumb the back of the intake cause I kept taking out exhaust valves 6 and 8 cause they were overheating. No water was not flowing through the back of the block with the new heads. |
Originally Posted by Rookie
(Post 3787668)
Head gasket could be a possibility, as would a leaking riser gasket or cracked manifold / riser. Was steam coming from just one side, or both? Sometimes it is not that uncommon to see a little steam in the exhaust, depending on weather conditions. Cooler air tends to show it more.
My gaskets were fine. It was just the head and Generation combo. It would take a valve out in 30 seconds once on plane. I had 2 identical engines and it only would happen on one engine. Water temps always read below 150*F, but temp is taken off the front of the intake. I also removed my water pump in place of a crossover.
Just drilling out the back of the intake took care of my problem. Here is a thread chronicling my troubles. http://forums.boatfreaks.org/showthr...t=piston+valve |
(Post 3787760)
(Post 3787752)
Did the valve break twice in the same spot? Same cylinder bank? Cold water on a glowing hot exhaust valve will take it out.
Of course too lean, not enough timing, can also take out exhaust valves, but normally it takes out more than 1 valve. Id take a close look at the manifolds/tails for leaks. Esp in saltwater. |
[QUOTE=MILD THUNDER;3787841]Did the valve break twice in the same spot? Same cylinder bank? Cold water on a glowing hot exhaust valve will take it out.
Of course too lean, not enough timing, can also take out exhaust valves, but normally it takes out more than 1 valve. Id take a close look at the manifolds/tails for leaks. Esp the first time it was #2 this time it was #3, one thing were also thinking it was the machine shop that did the head work, this last time we orderd and took to someone else to have ferra valves put in! |
If they are not inconel then it is plain old valve failure, regular valves are a 50/50 shot after 400hp period, if it was inconbel then start looking for other issues, it normally takes a lot to hurt one even with extreme lean/heat, inconel usually dont break at the stem..
This was one of my valves this summer when I had a fuel issue at went lean, this IS INCONEL, it took abuse but did not break, thats why you run them..a little more time it would have gave, I got lucky... http://i36.photobucket.com/albums/e4...g/P8287701.jpg |
I will run inconel in any HP engine .....
Originally Posted by [email protected]
(Post 3787921)
Yep, make sure tbey are for sure INCONEL
I dont believe Ferrea calls them "inconel". I believe they are called "super alloy" and supposedly better and lighter than a std inconel valve. I believe "inconel" was a Manley label.
Originally Posted by MILD THUNDER
(Post 3788271)
The other thing also is you want to use a quality valve seat, and stay away from fancy multi angle valve jobs that have narrow seat widths. You want to keep the seat cut on the wide side , because that is where the exhaust valve gets its cooling from.
Ad
(Post 3788347)
Correct. "Inconel" is not a Manley patented term, but is simply a trade name for a particular stainless steel alloy that has excellent high heat strength. I think it was developed for aircraft jet turbines, particularly the vanes. I have heard good things about Ferrea's valves too - just make sure they are the super alloy and not a lesser material. FWIW, I had Ferrea exhaust valves in my previous 454, and I am pretty sure they were not the super alloys, and it lived. I have a pretty decent set of REV valves in my 489 right now. However, both of these engines were set up pretty rich, and I guess I was lucky to have never had a fuel pump start to let go, or a fuel restriction, or just a bad tank of fuel. As Full Force discovered, all it takes is one little episode that can lead to disaster and ruin an $8K+ motor. Isn't boating relaxing? ;)
It still sounds like exhaust reversion (water getting pulled into the combustion chamber).
MC |
It's simply the fact of not being INCONEL..... regualr vales cant take much, especially if you are in the 400hp range or more, with 330/365's they are fine ...approach 400 and its a huge issue with or without reversion... simple as that
| All times are GMT -5. The time now is 08:23 AM. |
