1996 mercuriser 7.4 still no spark
the distrubator and coil,moduel and pickup coil is new the distrubator sparks on the bench test , their is power to the red wire at the coil but no spark, key switch purple wire has 12 volts when cranking and the yellow/red strip wire has power to the starter when cranking but still no spark, the purple wire that goes into the ECM has no power and when i put 12 volts to that wire still no spark , anyone have anymore ideas, im running out of ideas, also did allthe grounds again all sensors are conected and good , no kill switch on this motor and no crank sensor , before the problem with the VST tank motor the engine ran good
The manual #16 has a great flow chart for this. Might be able to find it oline.
Distrubator cap
does the little center piece in the center of the Dist cap need to proturde down from the cap , mine is flush with the cap and looks sheared off flush with the cap >?
you should have a fuse and relay for the ecm,,,check fuses and swith relay with another one
Easy fix
You will need the flow chart:
http://www.boatfix.com/merc/Bullet/83/83_24.pdf and the wiring diagram: http://www.boatfix.com/merc/Servmanl/16/16F4R2.PDF This troubleshooting is very strait forward. |
make sure you have good clean tight ground also.
Thank guys will try these things tomorrow ill keep posted
Originally Posted by jimmie
(Post 3799043)
cool thankyoiu ill give it a try
i had the boat running fine but it only lasted about five mins then quit and back to no spark again
