want to put a 10-71 on my 502 motor.
Ok, here is my plans. I want to put blower on my 850 carbed 502 (which is in the boat now) for next summer. While/until I can convert my 540 drag motor to a blower motor and upgrade my lower unit. Got few questions. I don't plan on any more(MAX) than 8 lbs boost on the 502. Its got 9-9.5 comp. now with AFR 320 alum heads.
Questions #1.....I've already have 2 850 holley double pump carbs, can I make them work (since I already have them)even though the formulas say that a couple of 750 0r 800's would be better suited? #2......its got a 500 hp camshaft. Do I need to swap out for a blower cam? #3..... the heads on drag motor are Pro one 355 CNC ported, should I put those on the 502 motor? Will the bigger heads help or hurt an over-carbed motor? And what about the torque? Are those heads too big for mild 502? P.S. This will be just a weekend fun run boat(502) with few hrs. put on it. And won't be ran hard until I can afford to swap out the Bravo1 |
10 71 will work just fine,compression needs to be 8 to 1 or 8.5 to 1 max.hp 500 cam is not going to work with a blower motor,the 320 heads would be my choice,355 cnc darts to big for a 502.your 850 carbs will work with some mods.
If truly 9.5:1, I wouldnt run more than about 3lbs of boost.
Pm weld crane, he took the efi and whipple side mounts off his 500 efi's and installed 10:71's. Not sure what he did for cams etc.
The 500 efi cam would work better with a supercharger than the HP500 carb cam. If your motor is a stock hp500 it's more like 8.8:1 I believe
Originally Posted by MILD THUNDER
(Post 3802143)
The ZZ502 was 9.6:1 with the 110CC chamber heads. If your using the GM Rect port Iron heads, they are around 119cc. That combo will get you down around 9:1. With a slightly thicker head gasket, you can probably knock off another .2. But, you really need to measure the quench area, and cc a chamber to be sure. If the piston's in the hole .020, you dont want to run a .066 thou headgasket, and have .086 quench height. I'd keep it around .040- .060 on a supercharged deal, and around .035-.050 on a N/A.
(Post 3802649)
The 850's will work fine for your setup. I'd actually choose them over the 750's for your app. I'm running 850's on a smaller blower and smaller 468ci. 800hp 6.5 lbs of boost. Engines run and idle like a dream.
Originally Posted by Drinkin fountian
(Post 3801975)
Ok,
