Bravo three question
When i put the drive on i put the aluminum ring on the rubber inside the bell housing what stops the water from getting inside the bellows from behind the aluminum ring once you install the drive and tighten it up ? is their a rubber 0 ring that goes on the drive that will mate up to the aluminum ring when its together ?
yes, it actually is installed into the helmet first, then you put the drive on
fixx
Originally Posted by jimmie
(Post 3805328)
ok so the drive it self has a seprate o ring the size of the alminum sleve that goes on the drive housing back at the flat spot wher it mates up to the bellhousing ?
fixx
(Post 3805576)
| All times are GMT -5. The time now is 06:15 AM. |
