What are these connections for?
I was recently working on a 41' outterlimits and saw these connections. They look as if they are some kind of hydrolic lines for something. If you have any info about this please comment. I will post a picture.
Probably freshwater flush fittings. Did you try tracing out the houses from the fittings to see where they went?
Yeah the go into the hull. I know they aren't flushes because they are completely seperate from the engines.
i want to say they are for airing out the hull,,dont know if its done with air or water??
Explain what you mean when you say "airing out the hull"
| All times are GMT -5. The time now is 11:34 AM. |
