Timing a 1997 7.4 bravo
is there not a timing tab for a Gen VI 454, how do you time this to 8 degree BTC without marks? The timing tab is just a pointer???
http://i556.photobucket.com/albums/s...nks/timing.jpg |
efi?,,short out a$b on the aldl plug and line up the pointer with the line. efi is usually zero...
Originally Posted by mrfixxall
(Post 3815236)
Sorry I should have gave more information Its a Carb motor, I dont think it was ever an efi |
apparently it has been painted over. I quick method without going through all the other suggestion that will come along is to measure the diameter which should be 8 inches
Circumference = Pi (3.14) x Dia (C=pD) result = 25.1327 / 360 dgrees = .069 inches per degree .069 x 10 degrees = .69 You can now make a mark approx .69 inches to the right of the TDC marker. Set the timing This will apply to an engine unless you are racing the crap out of it |
fixx
Originally Posted by rte203
(Post 3815239)
on somthing like that and most of the time you cant read the ignition module to see what advance number is on it i will use a advance timing light and line up the line on the ballancer with the pointer at 3500 rpm..you take the timing light and set the dial at 32* and rev the engine to 3500 rpm's and line up the marks.. http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_x_25980117-P_x_x?cm_mmc=ACQ-_-Google-_-enhancedRM-_-25980117&ci_src=17588969&ci_sku=25980117&ci_gpa=pl a&ci_kw={keyword}&gclid=CNXarJDnz7MCFYQ7MgodME0A 3g |
Originally Posted by tunertech
(Post 3815246)
(Post 3815247)
BTW ^^^^^^^ method is not accurate..
| All times are GMT -5. The time now is 09:11 AM. |
