Pro charger pulley measuring
When you measure a procharger pulley (12rib) do you measure from the outer lip (widest part of pulley) or the inner lip (where the belt would actually ride)? Thank you!
Call pro charger would be your best bet.
Good point! I am just at work and can't really dilly dally on the phone with procharger...... Thought someone on here might know?
If it is the same as my pulley its to the inside where the belt sits .
Originally Posted by paul buckner
(Post 3816371)
Split the difference?
Originally Posted by rob vanharten
(Post 3816378)
Thanks Paul, this is what I assumed, but wasn't sure. Can anyone else confirm this???
Thank you!!!
It is measured at the root diameter of the pulley.
Originally Posted by ckin62
(Post 3817168)
| All times are GMT -5. The time now is 07:17 PM. |
